Hi Tom......It's been quite some time since I had done a retrofit of a Studer S35 grinder with Kflop and Kanalog. Probably near 2 years. The machine has been working fine for a long time, then the owner moved the machine and has been unable to get it to work since.
I spent a few hours over there today, and I believe that the DAC outputs are not functioning. The drives are analog Siemens SimoDrives. If i bring up the analog screen after initializing......they show 0 volts. The drive enables are outputting properly. I have a feeling that I'm overlooking something obvious. The encoders are counting fine.
The init program is unchanged from the former working edition. I replaced it with a backup that I made from the last time I worked on it, and the result was the same.
I used a technique in the SimoDrive manual to jumper the analog inputs to see if the drive would hold, and it worked properly. This is what lead me to believe that for some reason the DAC's are not outputting.
Any ideas about this?
Seems very odd to me since i cannot detect anything different in the setups that were working before.
Mike
